Author Topic: Help rebuild filter board  (Read 1810 times)
Offline jamoraisTopic starter
  • Country: pt
« on: March 30, 2024, 10:39:38 am »
Hello everyone.
I need your expert advice on what i think is a simple matter.
I believe i have a 3 phase mains filter board from an industrial rectifier.
The thing is very corroded and it seems it have been tampered with before.
2089424-0
2089430-1
2089442-2
Now this is what i came up with after tracing.
2089436-3
Makes sense?
Seems to be only some X2 caps and discharge resistors.
X2 between Ls and N are X2 0.47uF 275V
X2 between PE and L-N are X2 4.7nF 275V
Discharge resistors seem to be 10Mohm
What improvements do you think i could make, if any?
« Last Edit: March 31, 2024, 08:35:48 am by jamorais »
Offline jonpaul
    • IEEE Spectrum
Re: Help rebuild filter board
« Reply #1 on: March 30, 2024, 12:20:27 pm »
need schem of rectifier and load to comment.
Very high transient energy on 3 ph industrial mains bus due to inductive loads.
j
An Internet Dinosaur...
  • Country: pt
« Reply #2 on: March 31, 2024, 08:35:17 am »
Thank you jonpaul.
I wish i had the schematics for the rectifier.
I can tell you that these are rectifiers used for plating lines.
Their typical load on the output is around 12VDC - 800A (max 2000A), and about 400VAC - 25A in the input.
Hope it helps a little  :-+
