if i recall, the cpu is controlled by voltage not data signal etc... unless you have a button key stuck, you should see a voltage between zero and 5 volts
maybe q906 or q907 have problems, normally they act as a switch, maybe not, check key 1 and key 2 pins on the main connector, you should have some voltage too
