Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Replacement transistor for a PSB subwoofer
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Replacement transistor for a PSB subwoofer (Read 1664 times)
mjrpainless
Contributor
on:
March 09, 2018, 02:44:53 am »
Hey all, hope that someone might be able to point me in the right direction.
I have an amplifier board for a subwoofer that I am trying to repair. I have narrowed it down to a bad transistor. But am unable to find a replacement tx.
the sub is a PSB Century Subsonic 2i with an Indigo MAIN 600049 REV 7 board. The transistor that is blown is a HARRIS IRF9543.
I was able to find a replacement samsung i believe it was, but they are only rated up to -60V (this is from memory so if its wrong I'm sorry)
Thanks all
Logged
Kleinstein
Super Contributor
Country:
Re: Replacement transistor for a PSB subwoofer
Reply #1 on:
March 09, 2018, 09:06:05 am »
Is this a linear amplifier with a large heat sink, or a class D type with a choke ?
The required voltage rating depends on the actual supply used. Especially linear MOSFET amplifiers tend to use higher voltage MOSFETs because of the often better SOA and not because they need the high voltage. So the voltage rating might not matter. However for linear use the SOA does matter and here different manufacturers might differ.
If in doubt, there is a 100 V rated IRF9542.
Logged
Rog520
Regular Contributor
Country:
Reply #2 on:
March 09, 2018, 04:26:34 pm »
A couple of sources pop up on Google:
Newegg, through a third party Chinese seller:
https://www.newegg.com/Product/Product.aspx?Item=2A3-0029-09K92
HB Electronics, out of California:
http://www.hbelects.com/product-6117/IRF9543
I have no experience with either one of them. Rochester also has them available, at a steep MOQ.
Logged
mjrpainless
Contributor
Reply #3 on:
March 09, 2018, 11:01:43 pm »
Thanks Rog520, i was able to find the ones on the hdelects.com, but was unable to order from them. It wouldnt let me put anything in the shopping basket.
and i didn't seen the ones that were on Newegg. so i made an order, Thanks for the help!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
