I am hoping that someone will be able to give me some advice on what to try next in the restoration of an old RC dump truck (1980s vintage). I started this as a project to try and advance my electronics knowledge.
With both the remote and car powered up nothing works and unfortunately I do not have access to anything that would be able to measure the RF output.
Unfortunately the truck does not have any indicator lights to show it has powered up ok.
I have probed the circuit as best I can and it seems to be getting power to the chip, but as mentioned above I have no way of measuring the RF output.
I have checked the motors and they are all working (steering, tip mechanism and wheel drive).
I have cleaned up the battery compartment, desoldered and resoldered, as it was a bit crusty from holding some old batteries.
I have replaced all of the electrolytic capacitors, though they all tested fine out of circuit.
The main chip is a TA7557P.
Let me know of any other info you need.
What would people suggest is the next best step?
Maybe this is the excuse I need to purchase a scope
Thanks in advance for any assistance.
