Author Topic: Simple switching power supply repair help please  (Read 7655 times)
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Simple switching power supply repair help please
« Reply #25 on: July 26, 2017, 06:53:20 pm »
Your clue is that it can't maintain aux supply.  Some part of the aux supply is broken.
Seven Transistor Labs, LLC
Offline PowerspringTopic starter
« Reply #26 on: August 19, 2017, 05:44:38 pm »
The LD7751 arrived from aliexpress. I swapped it in and ran the PSU with lamp in series with mains.
Success! PSU working well. Output voltages within 10%.
Unfortunately the hi-fi has one dodgy speaker driver but at least the unit works and I've learnt a lot in the process.
Thank you for your help!
