Author Topic: UNI-T UT210E Problem  (Read 4308 times)
Offline HolidayBobTopic starter
« on: August 16, 2017, 08:34:05 pm »
Hi all,  I have a UT210E which I bought from Asia a few months back.  I have noticed that the AC/DC voltage it's way out.  All the other ranges OHMs, current etc are working spot on.  I have tried to do a re-calibration by holding down the Blue/Yellow buttons and switching on, it goes through and returns ERROR 0 which I assume is correct.  So my question is are there any trimmers inside the unit I can adjust to sort out the voltage problem?
I look forward to any help anyone can give.
HB.
Offline MosherIV
Re: UNI-T UT210E Problem
« Reply #1 on: August 17, 2017, 08:34:24 am »
Hi
Welcome to the EEVBlog forum.
There are no trimmer pots in the UT210E for calibration. The calibration is held in EEPROM.
Details can be found in this thread
https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/375/
« Reply #2 on: August 19, 2017, 06:53:30 pm »
Hi MosherIV, Sorry for the very late reply and thanks for the reply and welcome.  So if there is no way I can fix this easy looks like I will have to put up with it.  I just checked a voltage fro my bench power supply which is set to 9V DC, measured on the 210E it reads 11.78V dc!
HB
