You need to get the manual and follow the service procedure.
Each divider step depends on the output of the previous divider.
Each divider is an analogue circuit, not a digital circuit. Each incoming pulse dumps a glug of charge onto a capacitor. When the voltage reaches a threshold, the capacitor is discharged and that pulses the next divider.
There are trimpots controlling that process, and they need to be tweaked to get a divider stage to work.
You will need a scope to watch the waveforms as you tweak them.
Make very sure you understand which bits of exposed metal are at >100V - and don't touch them!
I take it you have encountered that issue before.
I resurrectected my 184.
As far as I could check, the crystal is calibrated. Although I don’t have a lab-grade frequency counter, all the markers that work are absolutely dead on on my 485 and 475A, as well as on my other scopes (7623, 465, 465B, 466, etc.... I guess that must mean something, unless they are all not calibrated, and exactly in the same way...
Your scopes are 2% instruments. It would be remarkable to find a crystal that was 2% off. Anything derived from that will either be as good as the crystal, or not work.
I have a printed version of the manual albeit not a very good copy. I have a feeling this is not gonna be easy....
Take it one stage (literally!) at a time.
Firstly make sure that all the front panel controls are in the correct position; some controls prevent other controls from operating as you would expect, because one part of the circuit steals power from other parts. Get it so that you see a 1us output.
Then there are three main possibilities: the low voltage transistor PSU, the big front panel switches need cleaning, or some of the trimmers need tweaking. Cleaning switches can be done with either IPA or a DeOxit, or both.
The schematic shows the waveforms you would expect to see. Start at R140. If that is right, look at R154. If that isn't right, tweak R146. Then repeat for other stages.
As for the 100V, I never ever touch anything inside an electronic device; particularly one with high voltage capacitors, let alone a live one. I do a lot of tube amps builds and repairs, so I know better than to put my hands where they don’t belong. Don’t ask me how I know!
Make sure you have a *10 probe, not a *1/*10 probe! Your problems lie in the 12V domain, not the 120V domain!
