TV is an Alba ATVD91186P (Unable to locate circuit schematic)
A friend found that their kitchen TV was no longer working.
A check of the power board showed that 1 of the 2 secondary paralleled schottky diodes (SB5100 - 50p each) was dead short.
Both diodes changed & set tested via variac - isolating transformer & 70W load limiting lamp.
Standby led now lit, & set turned on via remote.
Brief screen flash & then set shut down with load limiting lamp flashing very briefly. (Sec voltage steady at 12.66V until shut down)
This prompted me to suspect one of the four 470uF 25V capacitors on the secondary side - all changed but no improvement.
Then decided to try my lv power supply directly on the 12V secondary side of the psu.
Everything worked normally at 12 V 1.80 A. (Set is nominally rated at 45W on mains side)
Screen illuminated, picture & sound normal, remote working correctly. Ran for 2 hours without any problems or excessive heat.
So it seems that the ccfl strips & drivers are ok. As is the main board.
Options are:
Throw the whole thing in the bin & admit defeat
Adapt the set to run on a 12V input direct from a power brick (approx £7), but it would be more satisfying to repair the fault.
Fit a used replacement psu board, available for £20-30 but not economically viable.(TV was only a cheapy originally & now virtually worthless)
Hopefully, one of the great brains on this forum will say "Simples, the fault is?"
Have watched a lot of smps videos, but none with this fault.
My thinking is that as the original fault was a shorted diode, the fault must be on the secondary side?
(But that works fine with direct 12v power to it).
If a primary fault, would the module not be permanently damaged? & not re-settable.
If a protection shut down, why when the load seems normal?
Sorry to be a little long winded, but grateful for any feedback.
Max.
