ZXMC3AM832, Zetex, COMPLEMENTARY 30V ENHANCEMENT MODE MOSFET, N-ch + P-ch, 30V/3.7A & -30V/-2.7A, marking C01, MLP832 PACKAGE:
https://datasheet.octopart.com/ZXMC3AM832TA-Zetex-datasheet-124599.pdfThis part has the correct marking, but its pinout looks wrong (mirror image):
https://www.semiee.com/file/backup2/SILIKRON-SSF3056C.pdf (marking 3056C)
http://silikron.com/upload01//SSF3056C%20v1.0(preliminary).pdfI expect that the pinout of the 3056C part would be the same as the C01 part. It looks like they may be wired as half bridges, in which case two of them would constitute a H-bridge.
The horizontal line on the 5FHC part identifies its manufacturer as probably Monolithic Power. It looks like it might be a stepdown DC-DC converter.
U4 looks like a linear LDO regulator.
I think this could be the pinout of U2 ("5FHC"):
__
NC -o| |o- NC
Boost -o| |o- Feedback
Lx -o| |o- Gnd
VCC -o|__|o- Enable / Power Good ?
U2
I would examine the other PCBs to see whether the manufacturer has substituted equivalent parts from other IC makers.
I would also compare the part markings on all the PCBs to enable us to determine which markings are date codes or batch codes.
Can you tell us what the markings are on the BGA-9 IC? I suspect it is an audio amp made by Texas Instruments.
Here is a TPA2028D1YZFR BGA 9 Ball 3.0 W Mono Class-D Audio Amplifier with a similar marking style:
Edit:
This looks like it:
TPA2034D1, Texas Instruments, 2.75-W FIXED GAIN MONO FILTER-FREE CLASS-D AUDIO POWER AMPLIFIER, 2.5V - 5.5V, marking BPZ, DSBGA:
https://www.ti.com/lit/gpn/tpa2034d1Edit #2:
Monolithic Power's web site identifies the package style as "QFN-8 (2mmX3mm)". The part number has a "D" suffix. Also, the marking info identifies "5F" as the part code and "HC" as a Year/Week date code.
https://www.monolithicpower.com/en/support/package-information.htmlhttps://media.monolithicpower.com/cms_document/Package%20Information/QFN-8%20(2mmX3mm)%20TOP%20MARKING.pdfhttps://media.monolithicpower.com/cms_document/Package%20Information/QFN-8%20(2mmX3mm)%20POD.pdfHere it is:
MP2452DD, Monolithic Power, 1A, 3.3V - 36Vin, 1MHz, STEP-DOWN CONVERTER, marking 5F, QFN-8:
https://www.monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/MP2452/document_id/255/
