Hi all,
I'm repairing a radio stack from a flight sim (an old Cirrus 2, from precision flight controls for those in the know!), a couple of the dials used to tune the radios and other bits are either broken or snapped completely.
What I'm after appears to be a resolver rather than an encoder, I'm only guessing based on the number of pins it uses (3 per shaft) and the ones that do work, if you turn them too fast it just can't cope, which screams resolver to me. I don't have much to go on and all my googling is currently drawing a blank, I suspect the part is obsolete but anything that will do the job will do, I just want it working again even if it takes a little modding.
I've added a couple of photos, but there isn't much to go on, I cant see a manufacture (just what looks likes a star symbol) and all the numbers draw a blank for me. If anyone can help out at all I would really appreciate it. No response from the precision flight controls which is a bit annoying.
Thanks all!
