Author Topic: Help sourcing encoder  (Read 1510 times)
Offline jheatacTopic starter
« on: January 05, 2018, 09:17:34 pm »
Hello,
I have a volume encoder that I cannot seem to find. It is in a Monster branded MP3 player, however I only have the board, not the whole unit, so I don't know the model.
The only marking is on the back. I will take a picture in the next post.
Vertical, PCB Mounted with panel nut (not used in this application), Mechanical, 20 PPR, w/ momentary push button. knurled shaft - I believe would be 6mm, 25mm long (this seems uncommon)
3 terminals are 2.5mm apart
2 terminals are 5mm apart
2 mounting holes in PCB look to be 11mm centers or 11.75mm outside to outside
terminal rows are 14.8mm apart (2 on one side, 3 on other)
11.7mm wide x 13.8 long x 7.2mm tall not counting panel mount or shaft.
My measurements may be just a little off because I don't have a set of metric calipers. I'm converting thousanths to mm with a calculator.
Thank you for your help
Re: Help sourcing encoder
« Reply #1 on: January 05, 2018, 09:21:17 pm »
Here are pictures
Sent from my SM-G920V using Tapatalk
Offline saike
« Reply #2 on: January 05, 2018, 10:26:18 pm »
Did you remove it with a hammer or an axe?  :-DD
The link is to a gray encoder but it looks as though it may be from the same family?
http://uk.farnell.com/bi-technologies-tt-electronics/en11-hsm1aq20/incremental-encoder-100rpm-5vdc/dp/2787193
« Reply #3 on: January 05, 2018, 11:12:20 pm »
I
The knob broke off which is why it is being replaced.
The desoldering iron wouldn't free the pins. I cut the 5 connectors and wiggled the mounting tabs out, then I heated and pulled the pins individually.
I then took it apart to count the number of tabs on the wheel.
Thanks for the reply.
I have found several bases that would fit up, but the shaft isn't long enough. I will check it out. Thanks!
Offline saike
« Reply #4 on: January 06, 2018, 12:23:51 pm »
My quip about the hammer was a very poor attempt at humour,  which now I look at it again seems like an aspersion on your component removal skills which it definitely wasn't.
I just thought about it a bit and surely a 2 bit gray encoder must have the same output as an incremental encoder?
So maybe the device in the link is the same one as the original.
« Reply #5 on: January 06, 2018, 03:10:17 pm »
I took no offense. Your assessment based on the pictures were pretty well spot on!
I am very much a newbie at electronics. It looks to me that a mechanical encoder has the pulses split evenly at 50% of the cycle. A gray encoder looks like the cycles are slightly offset. Is that the difference?
Offline saike
« Reply #6 on: January 06, 2018, 07:33:52 pm »
It looks like that to me from looking at the data sheet. It should still work ok whatever the original item is.
