Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
SMPS dc-dc 12V-atx
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: SMPS dc-dc 12V-atx (Read 910 times)
raresvintea
Contributor
SMPS dc-dc 12V-atx
on:
January 02, 2016, 10:13:23 pm »
Hello i have this dc dc 12V-atx power, and i've burned it by puting 30V instead of 12 on the imput. I was finding a 4435 Mosfet shorted and now the 5V standby voltage is ok. But when i want to put the green to the ground no voltages. i've removed some caps to test the with the ESR meter. Sorry for the messy weldings. I want to repair to find out how it works!
The big IC is ISL 6225CAZ and the IC from the left is 1507 0537 AL. I've tested the other mosfets and it seemed fine.
Any oppions are ok and any obersevations are great!
Logged
SeanB
Super Contributor
Country:
Re: SMPS dc-dc 12V-atx
Reply #1 on:
January 02, 2016, 10:22:51 pm »
Buy a new one, as it is very likely the main converters are both blown. If you applied 30V to the mainboard of a PC as well that will definitely be fried as well, along with the CPU and probably the memory, along with any boards plugged in as well.
Logged
raresvintea
Contributor
Reply #2 on:
January 02, 2016, 10:30:07 pm »
The board was an older one and it died. I wanted to repair and to learn. It's not the firts one and i hope not the last one
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
SMPS dc-dc 12V-atx
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Library
