Author Topic: Help to ID smd diode  (Read 1199 times)
Offline cozzaTopic starter
« on: November 11, 2021, 11:10:51 pm »
Hi I have a few dali LED ballasts to repair, in all units the diode / TVS has failed shorted and blown the series 4.7k resistor.
I don't recognise the logo unfortunately - can anyone help ID this diode / TVS?
Initially I thought from the DK marking it might be be an SMBJ60A uni-directional 60V TVS, but that does not make sense in the circuit.
The resistor connects to HV + and the anode of the diode to HV +. The common point connects to an HV startup / line voltge sense pin on the IC, HVLED001A.
I've measured a working unit and there is up to 314V DC across this part - ruling out the 60V TVS part. It's not part of the application note for the IC, looks like a blocking diode.
Any help appreciated :)
Re: Help to ID smd diode
« Reply #2 on: November 13, 2021, 03:24:44 am »
Thanks, but that's not really helpful.
I can't find a substitute for it if I don't know the specs yet.
It could be a diode or a transil.
Offline fzabkar
« Reply #3 on: November 13, 2021, 05:20:08 am »
Can you tell us the date codes on the other parts? I'm thinking that "09" is a date code, but I'd like to be more confident.
« Reply #4 on: November 14, 2021, 07:47:05 pm »
Hi Fzabkar. A few of the ICs have a 2018 date code, the QC stickers on the ballast indicate week 48/ 2019.
Thank you!
« Reply #5 on: November 24, 2021, 12:51:47 am »
Hi I'm bumping this request again. Can anyone ID the manufacturer's logo on the device?
Searching semi manufacturer logo lists has so far turned up no match for me :(
Offline maxwelllls
  • Country: cn
« Reply #6 on: December 02, 2021, 05:59:31 am »
DK mark,maybe is a 14V zener diodes,MMSZ4701
The following users thanked this post: cozza
