Author Topic: Help to identify a component  (Read 2855 times)
Offline nmacTopic starter
« on: April 04, 2016, 06:20:58 am »
Hello all,
This is my first post... and my first consideration and question is: Should I post it here?  :-DD
I trying to repair a hair dryer with some rotate function and ceramic stuff... and found this component on image attached.
a slow motor is the issue... probably - and I think - after a broken resistance made a intermittent contact turning on/off this device many times
caused a sequence of inrush current on capacitor and a consequently degradation of it. I don't know, I speculate it could be a capacitor. hehehe But its not the usual info printed on, right?
I can't find on Internet some spec or datasheet for this one.
Someone have any idea what is this?
Thanks!
Offline Cloud
  • Country: si
Re: Help to identify a component
« Reply #1 on: April 04, 2016, 06:22:44 am »
My first guess would be a filter
Offline Gyro
« Reply #2 on: April 04, 2016, 09:10:42 am »
That looks like a step-up converter - 4.7kV out. I'd guess it's one of those 'Ionic' hairdryers.
P.S. I doubt it has anything to do with your problem, it's fed directly from the supply and just feeds some sort of spiky electrode near the hot end. The fan motor is usually fed from a tap on the element winding via a (possibly bridge) rectifier. Check for failed diodes. A common reason for slowing down is loose hair wrapping itself around the motor shaft until there's no free play left.  :palm:
« Last Edit: April 04, 2016, 09:31:11 am by Gyro »
Best Regards, Chris
« Reply #3 on: April 04, 2016, 03:32:12 pm »
Agree on the loose hair, but also a drop of oil on each oilite bush ( one under the fan so you will have to pull the fan, and get the loose hairball out first before you oil it) of the motor will work wonders. Diodes are also common, but generally you can check in circuit as they tend to go short circuit or break in half.
« Reply #4 on: April 04, 2016, 08:19:43 pm »
Thanks for all!
Gyro, makes sense. I'll verify diodes. SeanB, the problem isn't mechanical, but a drop of oil isn't a bad idea.
I'll try those things and let you know if it works for me.
Thank you!
« Reply #5 on: April 04, 2016, 11:51:25 pm »
That's it! Just a diode.
Thank you, guys!
I really enjoyed this forum!  :clap:
The following users thanked this post: SeanB, Gyro
Offline Macbeth
« Reply #6 on: April 05, 2016, 12:24:46 am »
Thank you, guys!
Past tense? Ok, fine... Don't forget to close the door on your way out!  ;)
« Reply #7 on: April 05, 2016, 08:43:41 pm »
hahahaha... using cell phone.. :palm: sorry..
I swear I'm still enjoying this forum hahaha
