Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
SOLVED..Thanks)Help to identify a transistor in this Rivera guitar amp schematic
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: SOLVED..Thanks)Help to identify a transistor in this Rivera guitar amp schematic (Read 2072 times)
Planobilly
Regular Contributor
Country:
on:
May 05, 2016, 12:08:42 am »
http://bmamps.com/Schematics/Rivera/Clubster%2025-45.pdf
This is a Rivera Clubster 25 guitar amp.
From the input there is R102 to C101 to Q101 which is marked as 1FN6448 on the schematic. There is only a Rivera part numbers on the transistor. I assume it is a transistor. Round metal top with three legs.
What is Q101? Data Sheet?
Thanks,
Billy
One of the issues is that I have no signal on the grids of V1 and I assume this component may be the cause.
Last Edit: May 05, 2016, 02:47:39 am by Planobilly
Logged
Andy Watson
Super Contributor
Re: Help to identify a transistor in this Rivera guitar amp schematic
Reply #1 on:
May 05, 2016, 12:33:52 am »
It is a junction FET. Can you read the part number on the device? Could it be 1FN644
9
Q104 appears to be a 1FN6449 - if this is the correct part number it is a Jfet made by InterFET. They claim it is equivalent of a 2N6449.
http://www.interfet.com/Support/JFET-Naming-Conventions/
Datasheet:
http://www.interfet.com/datasheet/IFN6449/
Last Edit: May 05, 2016, 12:47:23 am by Andy Watson
Logged
Planobilly
Regular Contributor
Country:
Reply #2 on:
May 05, 2016, 12:48:49 am »
No part number other than (Rivera 104-010-0450) that is marked on the device.
I assumed a FET of some sort. I think it is possible that it is a 6449. The schematic is a PITB to read!!!!
Also...thanks for the help
Cheers,
Billy
Last Edit: May 05, 2016, 12:56:04 am by Planobilly
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
