Hello,
I am a non-techie beginner in DIY electronics, recently my wireless mobile charger went bad (which is apparently a common problem as I read around) . The charger does only blink blue light when the phone (Samsung Galaxy Note
is put on it and I tried several phones from friends as well. The charger came as a part of the Galaxy S7 Value pack and made by AnyMode.
The charger specs are follows :
Here is the disassembled charger.
Upon visual inspection of the PCB, it is apparent that a blue square part (possibly a capcitor) is busted by swelling and overheating and most probably the cause of charger not working as intended. Highlighted in red box.
I am usually fine at soldering tasks and have the basic tools at hand. Can anyone please inform
1. If the noted cause could be the reason of malfunction,
2. What is this part / part number /part specs .
3. Any online store/link where I can buy the part.
Would try to repair it myself before buying a new one, maybe it will work
Thanks for reading and your expert guidance.
Ok it is a film capacitor apparently.
https://www.google.com.sa/search?q=film+capacitors+u33k&num=20&safe=strict&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiY_MPRgN7dAhXMTd8KHfPIAMkQ_AUIDigB&biw=1440&bih=709#imgrc=_Can anyone inform me what is the exact specs of it to be replaced.
Thanks.
