Author Topic: Help to identify this switch  (Read 2371 times)
Offline spilihpsTopic starter
« on: August 15, 2017, 11:50:01 am »
Hello!
So i have a broken PCB switch.
It is a non latching (sorry dont know the correct english world)
Its used as a powerswitch for a PC.
Please see these images:
Please ignore the piece of copper inside the switch on the last picture, i found that and just put it there to know were it is. It have two of those. Probably goes on either side?
image uploader
« Last Edit: August 15, 2017, 12:46:17 pm by spilihps »
Offline MrPCB
Re: Help to identify this switch
« Reply #1 on: August 15, 2017, 12:53:35 pm »
Looks very familiar..
Can't place it right now, I'm sorry
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #2 on: August 15, 2017, 01:28:20 pm »
Search for "latching push button" probably with the remark "PCB mount" "right angle" ...
Here is an example: push button switch
you would need to figure out the mode of operation however. It can be SPDT, DPDT, DPST... My guess would be SPDT ON-ON or DPDT ON-ON. Are there any manufacturer markings? Do you have a schematic?
Regards,
Frederik
He’s like a trained ape. Without the training.
Offline fcb
    • Electron Plus
« Reply #3 on: August 15, 2017, 06:43:49 pm »
Possibly an ALPS SPUJ or SPUN
« Reply #4 on: August 15, 2017, 07:40:56 pm »
Hello guys!
Thanks for your help.
I found that it says "ITT" on it. That is the only markings. However, that manufacturer doesnt seem so easy to find here.. So a equivalent would be great.
« Last Edit: August 15, 2017, 09:27:58 pm by spilihps »
Offline frozenfrogz
« Reply #5 on: August 15, 2017, 08:23:08 pm »
« Reply #6 on: August 15, 2017, 09:34:11 pm »
If it only were that simple. that dont narrow it down much, since they probably make more than just one switch.
These are very close (i think) they are however latching, mine is non-latching.
http://www.ebay.com/itm/10pcs-ITT-C-K-PHA2UEE-SWITCH-DPDT-PUSH-BUTTON-latching-RA-PCB-SP70300-0202-11F1-/121118476209?epid=1931526773&hash=item1c333947b1:g:4zIAAOxyHE5RpfQH
Offline frozenfrogz
« Reply #7 on: August 15, 2017, 09:52:09 pm »
You need to figure out the switching action, then you can do the measurements on the pins to see what pitch you need. Afterwards Mouser, Digikey, RS Components, TME etc. will hook you up with various makes of switches that can quite easily be selected via your design requirements (type of switch, number of contacts, pitch of contacts, rated switching current,...)
We can hardly do the guessing for you. Hell we do not even know what device this sits in (PSU is a little generic), apart from the fact that this might switch 10A as well as 0.01A. Without more information: No can do.
« Reply #8 on: August 15, 2017, 09:56:23 pm »
I might have found a replacement.
C&K switch PHB2U0A1A seem to be a match.. also SN for angle..
So PHB2U0ASN1A it is still in manufacture, however very hard to get hold of it seems.
« Last Edit: August 15, 2017, 10:08:26 pm by spilihps »
Offline carl_lab
« Reply #9 on: August 16, 2017, 07:23:36 am »
On many of those switches you can remove the latch mechanism easily...
Example:
Remove part no. 6
« Last Edit: August 16, 2017, 07:33:30 am by carl_lab »
« Reply #10 on: August 16, 2017, 05:13:57 pm »
Remove part no. 6
Thank you very much for this information! That is very helpful.
Great!! :-+ :-+
