Author Topic: Help trace what the IC is connected to in a Gossen Metrahit X-TRA / Pro  (Read 774 times)
Offline giosifTopic starter
Apologies for the duplicate, but I thought I'd ask this explicitly, in case people are not following my other Gossen repair thread: could someone with a Metrahit X-TRA or Pro be so kind to check where the traces for the two IC pins in the green rectangle are going?
Thank you!
« Last Edit: December 14, 2020, 08:16:45 pm by giosif »
Re: Help trace what the IC is connected to in a Gossen Metrahit X-TRA / Pro
« Reply #1 on: December 18, 2020, 03:33:50 pm »
Anyone, please?
Offline Florian68
« Reply #2 on: December 18, 2020, 09:10:46 pm »
Maybe it helps you
The following users thanked this post: giosif
« Reply #3 on: December 18, 2020, 09:59:20 pm »
Many thanks!
Ok, so those two pins don't go to the customer ADC IC, but to the unpopulated section on the board (probably populated for a different model).
