so I have an old drum machine. it uses a 7 segment display with a bunch of buttons on a matrix for editing parameters/#. uses a z80 cpu.
Im having a problem where the display wont turn on. leds light up like it boots, but unable to make changes. seems like the cpu is freezing maybe but Im guessing.
strangely if I clip a logic probe on the q101 + line at 4.7v (2n3904) it makes the display light up partially and seems to get closer to functioning.
Ive seen 2 different results on 2 CD4042BE side by side that I think are responsible. on pin 10 when its closest to functioning presumably pin 10 was high, but 1 CD4042 is low on pin 10 if the display is blank. I should add that at all times 1.9v is going to each segments display. Im not sure if it was more when both pin 10s were high.
I do get a clock input pulse on logic probe on both 4042.
So Im wondering how can I know if 1 of those logic gates is bad. I tried looking at the datasheet but It was all over my head basically.
Theres also an OS eprom. I doubt thats the problem but I could try to rewrite that.
Heres the service manual
https://archive.org/details/sequential-circuits-420-tom-service-id-10946Any ideas on what to look at is appreciated. I am always guessing but have nobody to ask in reality. I have an oscilloscope, esr meter, logic probe, dmms, can test Hz, so hopefully whatever the culprit is I am equipped to check.
I tested the caps and they seemed to be fine.
tested q101 and it was good out of circuit too. part of me wondered if the 5v line wasnt enough to turn on the 2n3904? but I think of so many possibilities in uncertainty.
