Author Topic: Help: Vox Guitar Amplifier Seeks New Transformer to Make With The Beats  (Read 685 times)
Offline kazzle101Topic starter
Hello
I've been 'given' an old Vox Supertwin amplifier made in the early 1980's to to see if it can be repaired.
The transformer has failed, I can tell on account of the smoke that comes out when its plugged in. So I'm looking for a replacement transformer, and I don't normally do mains voltage stuff.
On the circuit diagram the transformer output is shown as being 30V at 1A: https://www.korguk.com/voxcircuits/circuits/suprtwin.jpg
Searching around I found this: Vigortronix VTX-126-050-215 Chassis Transformer 230V 50VA 15V+15V: https://www.rapidonline.com/Catalogue/Product/88-3931
Am I right I thinking I can connect the outputs in series to get the required 30V?
And is this the right transformer to get regarding power? - I worked out the needed VA by the following: 1A * 30V = 30VA
Thanks
Karl.
Offline paf
Re: Help: Vox Guitar Amplifier Seeks New Transformer to Make With The Beats
« Reply #1 on: February 24, 2021, 11:30:34 am »
Yes. It is a good replacement.
The following users thanked this post: kazzle101
Offline bob91343
« Reply #2 on: February 24, 2021, 10:03:06 pm »
Remember to get the winding polarity correct or you won't get output.
