Author Topic: Help, what does this chip code represent  (Read 441 times)
Offline daisizhouTopic starter
  • Country: cn
« on: April 12, 2023, 02:57:01 pm »
https://www.alldatasheet.com/datasheet-pdf/pdf/858934/DIALOG/DA9053.html
The chip manual information is on top,I want to know what the number 37 at the end of this DA9053 37 represents.
If you know, please let me know. Thank you
daisizhou#sina.com #=@
Offline inse
Re: Help, what does this chip code represent
« Reply #1 on: April 12, 2023, 03:42:08 pm »
30.1Variants Ordering Information
DA9053 supports delivery of customised variants indicated by xx in the part number above, please contact your local Dialog Semiconductor office or representative to discuss requirements
Offline fzabkar
« Reply #2 on: April 12, 2023, 04:38:44 pm »
Controlled by a programmable digital power manager, the 14 user-programmable switched/linear regulators can be configured to meet the start-up sequence, voltage, and timing requirements for
most applications.
I expect that a customer could define the default startup voltages and power on sequence for their particular application. "37" would refer to a particular configuration. FWIW, that's the way that Active Semiconductor marks its PMICs.
https://www.renesas.com/us/en/document/dst/da9053-datasheet
« Last Edit: April 12, 2023, 04:40:16 pm by fzabkar »
