Author Topic: Battery replacement HP 8901B  (Read 774 times)
Offline CramboneTopic starter
« on: December 09, 2022, 01:38:14 pm »
The 2.8v battery in the HP 8901B is said to be, “Non Volatile Memory” it is a 4331DE number battery.
Question is can I replace without jumping in a power source and just remove old and replace with new?
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
Re: Battery replacement HP 8901B
« Reply #1 on: December 13, 2022, 07:17:33 am »
I'm pretty sure that there is nothing held in RAM that relates to calibration data (i.e. the RAM is just working memory) - The service manual doesn't mention anything more than just disposing of the battery correctly - I've had my 8901 for almost a decade and haven't experienced any issue with the battery (it is only used I believe when the power drops to the unit).
TonyG
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #2 on: December 17, 2022, 04:18:18 am »
I did a couple of repair videos on the 8901B, I have included them below in case they are of help to you, I don't think I showed the battery replacement in them though.
Part 1:
Part 2:
Cheers Scott
