Hello and as usual thank you for helping other people.
I have on the bench a McIntosh MX121 that came in saying "the remote control is not working". Indeed, testing it aparently showed that except that it works well only when the unit is in standby and power on is pressed in the remote. The unit powers on ok but then, it responds to no other command from the remote.
So, issues with the electronics on the IR receiver is unlikely. Maybe somthing regarding a difference between the power supply to the IR receiver between standby and operation.
Anyhow, the unit inside is very complex, it is a A/V control center. So, having the service manual or schematic would make the job much straight forward and professional. I haven't been able to find this information yet. Can anyone help with the service manual, shcematic or tips on what can be wrong.
Much appreciated, Carlos.
Indeed, testing it
