Author Topic: Help with a Episode EA-AMP-8D-70A 8 Channel 70 Watt Amplifier.  (Read 627 times)
Online rfenggTopic starter
« on: September 18, 2023, 02:22:13 pm »
Hi All,
Need your advice on a Episode EA-AMP-8D-70A that I picked up at a garage sale during the weekend. The owner told me that it was broken and sure enough when I switched it on, there is a weird combination of LED's lighting up on the front panel.
I am yet to open the unit up but understand that the 8 channel amp consists of 4 modules and each module has 2 channels each.
What I am baffled by the LED status (pic attached) on the front panel which shows.....
LED 1 in a pink color
LED 2 in red
LED's 3,4,5 in blue
LED's 6 and 8 in red
LED 7 in pink
The manual says that "RED LED – Amplifier is ON and is not functioning properly"......I can understand that.....but the pink color (which means RED and BLUE are ON at the same time)???
Does anyone have a schematic or service manual for these amps? Any pointers to amps with similar circuitry would be great as well.
Have a good one.
