Author Topic: Help with a Smd identification  (Read 2771 times)
Offline ElendilTopic starter
« on: March 27, 2018, 03:31:29 pm »
Hi guys, i need some help to identify a Smd 6 pin part. I know It is a n-channel mosfet but the marking Code is confusing. Perhaps some of you can help. Please see the attached picture.
Enviado desde mi Aquaris X Pro mediante Tapatalk
Offline Samogon
Re: Help with a Smd identification
« Reply #1 on: March 27, 2018, 04:48:42 pm »
It is imho general use double transistor. Cant say for sure if it is pnp or npn.
« Reply #2 on: March 27, 2018, 05:58:13 pm »
@samogon, Thanks for your answer, but according to the electrical diagram It should be a mosfet (the one connected to the point 4P in the electrical diagram) and not a bjt transistor.
Offline Samogon
« Reply #3 on: March 27, 2018, 06:57:49 pm »
Then put some generic double package N-ch (if i see diagram correctly) mosfet like DMN3190LDW-7 logic gate it is 30V 1A should do the job
https://www.digikey.com/product-detail/en/diodes-incorporated/DMN3190LDW-7/DMN3190LDW-7DICT-ND/4457886
« Reply #4 on: March 27, 2018, 07:20:35 pm »
taking into account the PCB design, I suspect the smd should have a single mosfet inside. Some packages has one mosfet and 6 pin to handle more power. The problem is that is quite difficult to find the marking Code. The attached datasheet comes from Code 42 (readed in vertical in my smd part)
« Last Edit: March 27, 2018, 07:31:06 pm by Elendil »
Offline Samogon
« Reply #5 on: March 27, 2018, 07:36:26 pm »
Letter D possible indication that it is double package. You have board and schematics you can track if it is singleif it turns only glove compartment light then it is single transistor
« Reply #6 on: March 28, 2018, 07:48:50 am »
It is for the cargo (trunk light) compartment
« Reply #7 on: April 11, 2018, 08:50:14 am »
I found It. It is the cph6445-tl-w from onsemi. Single mosfet n-channel. Marking Code ZX.
