Author Topic: Anyone have a High precision LCR meter?  (Read 1197 times)
Offline ampliwireTopic starter
  • Country: no
« on: January 28, 2018, 10:44:13 pm »
Hello!
I have some inductors, that I need to get measured (mH, and Resistance).
They don't come with a datasheet, or any marking.. So that's why I need the values.
Does anyone here have access to a high precision LCR meter, capable of measuring in the mOhms, and mHenry area?
Kindest regards!
Offline Samogon
Re: Anyone have a High precision LCR meter?
« Reply #1 on: January 29, 2018, 12:05:45 am »
Fluke pm6306 in US
The following users thanked this post: ampliwire
Offline LA7SJA
  • Country: no
  • Acting user manual reader & forum search engine
« Reply #2 on: January 29, 2018, 11:29:11 am »
Define High Precision, and how many different inductors do you have?
I could be cheaper just to buy the inductors you need than to buy the LCR meter and hope you can use the components you have.
I don't know how many some are so I don't know ho much work it would be to test with a signalgenerator and a scope.
And finally where in Norway are you located?
Johan-Fredrik
"If at first you don't succeed, skydiving is probably not for you"
Offline Tomorokoshi
« Reply #3 on: January 29, 2018, 06:20:32 pm »
1. How many are there? How big are they? Maybe post a picture.
2. What frequency range to they need to be measured at? 100Hz? 120Hz? 1000Hz? 10kHz? Sweep from 100Hz to 40MHz?
