Author Topic: Help with bricked APC UPS SMT1500  (Read 28295 times)
Offline PeeJayTopic starter
« on: February 20, 2024, 04:09:00 am »
Hi, somehow I've managed to brick my UPS.  |O Not the NMC but the actual ups. I've tried the serial cable firmware update tool but to no avail.
I took the controller board out and discovered it's an STM32F103RC and they have very helpfully populated a SWD interface, so I dumped the ROM but the provided firmware file is not in a format I can figure out. (Both attached).
Any ideas what to do next?
« Last Edit: February 20, 2024, 09:03:43 am by PeeJay »
Offline DavidAlfa
Offline darkspr1te
  • Country: zm
Re: Help with bricked APC UPS SMT1500
« Reply #2 on: February 20, 2024, 06:01:54 am »
i dont see anything attached
darkspr1te
Offline DavidAlfa
« Reply #3 on: February 20, 2024, 07:56:29 am »
Yes, almost at the end there's an hex file!
« Reply #4 on: February 20, 2024, 09:05:42 am »
Sorry, the attachment didn't attach! It's on the first post now.
Offline darkspr1te
  • Country: zm
« Reply #5 on: February 20, 2024, 09:29:00 am »
file wont unpack, says un-supported 7z method,
« Reply #6 on: February 20, 2024, 09:45:40 am »
hmm I've noticed winrar doesn't like those files. Here is a zip. (I hope!)
Offline DavidAlfa
« Reply #7 on: February 20, 2024, 12:53:49 pm »
Better don't attach it here unless proved working, it's for a different model and might induce confusion.
« Reply #8 on: February 22, 2024, 03:06:49 am »
Ok, well for anyone who finds this post later here is the pinout:
6 - Reset
5 - Ground
4 - PB3 / JTDO
3 - PA14 - SWCLK
2 - PA13 - SWDIO
1 - VCC
It's the white connector in the photo.
I'm toying with the idea of buying another unit of ebay and then selling it once I fix mine. Will post the firmware if I manage to get it.
Offline asis
  • Country: ru
« Reply #9 on: February 22, 2024, 01:42:09 pm »
ARM STM32F103_C4 (IC603) data exchange with the main MPU 89C51RC -UM (IC11) occurs through connectors J710B-J710B (pin3-TX, pin4 -RX).
These buses (RS232) are also connected to the J606 pin3-TX technology connector; pin5 -RX.
This is the only connector through which you can access SW or perform calibration (in the traditional sense).
In this case, the module itself (PCB: 640-3081J-Z-001 _IMG_) must be removed.
As far as I understand, APC (Schneider Electric) planned to use technology for managing and servicing UPS of this generation via the cloud and, probably, by for this reason it was created.
ARM STM32F103_C4 (IC603) communicates with the control/display panel, NMC and RJ50-10 RTU.
Moreover, the navigation buttons are controlled based on ADC (PB1 pin27) and resistors corresponding to the values of:
-R200-604E “DOWN”;
-R201-1.2k "UP";
-R202-2.43k "ENTER";
-R203-3.01k "Escape"
All of them are connected to the midpoint of the divider made of resistors
(R205-2k +5V) * (R203-3.01k GND).
Pins PB10-pin29 (TX), PB11-pin30(RX) via IC601 (MAX3232) are connected to the RTU connector RJ50-10 pin2 (TX) and pin 8 (RX).
Pins PA2-pin16 (TX), PA3-pin17(RX) - directly via connectors J702B/J702A (pin5-RX, pin6-TX) connected to connector J2 and via a cable to NMC (AP9630, AP9635 pin8/9 [SUMX v6. 4.6]).
J602 JTAG - connector for programming the module and binding to a specific type of UPS.
IC904 93LC66 can be read. Most likely it's MAC/WWN.
SW update is carried out via NMC.
Most likely you downloaded the wrong version.
You can find answers to many questions and the firmware you need on the forum:
https://community.se.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=STM1500
I apologize for the boring description, there is no other way.
The following users thanked this post: PeeJay, audiotubes
« Reply #10 on: February 22, 2024, 11:51:18 pm »
Oh, so it's likely the 89C51RC/93LC66 with bad firmware then?
It's strange that I get no response trying to communicate via the RTU port. I made a cable according to https://pinoutguide.com/UPS/apc_0625_cable_pinout.shtml which matches what you wrote, I checked for continuity to the pcb pins as I was using a RJ45 connector. Perhaps I should have tried swapping tx/rx?
I've since seen a few other posts from people who had timeout errors like me when trying to flash via the web interface on the NMC, but I'm not sure if any of them managed to resolve it.
Offline NickPlays
« Reply #11 on: March 10, 2024, 12:13:22 am »
Just bricked my smt1000i also during a firmware update.
Luckily i got it for cheap so it isnt a huge loss but ill see what controlboard mine has.
edit: Tried the exact same firmware version you did....
Edit2: Mine has a 640-3081A_REV06 board. dont know if thats the main one.
« Last Edit: March 10, 2024, 01:16:13 am by NickPlays »
Offline asis
  • Country: ru
« Reply #12 on: March 10, 2024, 01:58:42 am »
You can see everything written above at this link:
The following users thanked this post: audiotubes
Offline blueman2
« Reply #13 on: March 15, 2024, 05:42:02 pm »
I also bricked my SMT1500 trying to update the UPS firmware.
Some of the info in this thread is way over my head but still curios to know if you were successful in recovering the UPS?
My control board appears to be 640-3081_REV03.
My unit is a 2011 manufacture date so about time to retire it anyway but it would be nice to recover it.
Bruce
Offline asis
  • Country: ru
« Reply #14 on: March 15, 2024, 11:57:14 pm »
Start with this:
Offline AstroAU
« Reply #15 on: March 30, 2024, 08:17:08 am »
Hi PeeJay,
I'm also in the same boat with a Bricked SMT1500. BUT I have TWO working ones, one with ID17 and the other with ID18 chip for the main device. This latter one I picked up brand new back in the day and acquired my 3rd one from Ebay for $250.
The Ebay one is also ID18 and unfortunately the one I bricked, as the original firmware for the sub board which was 9.2 and attempting to upgrade it to 15.0 is where it went awry.
So down the path of scouring the internet I come across this forum and your posts.
So it got me to thinking and sure enough my working UPS with ID18 has the same part number (640-3081A-REV006). But I needed to READ the EEPROM chip on the working one on the sub board you have displayed. The chip is an 8 pin SOP and marked 93LC66B1.
This is a 4kbit  EEPROM arranged in 256x16 configuration. After googling it and I found a programmer that supports 34,000 different chips on Ali-express (T48 programmer to be precise) with the right connectors etc.
I subsequently took my working UPS off line and removed the sub board and read the EEPROM after some fiddling to get the clip to connect properly. So I have a BIN file with the contents (I'll attach later). BUT upon trying to program the chip on the board from the bricked UPS, I get the error message that the EEPROM failed to be written too. the reason for this is because it's "In Circuit" and I need other connections to my programmer for me to attempt to do it that way. (Currently on order).
Also I noted while I had the bricked UPS disassembled. Their is another EEPROM on the main board near ID18 (AT89C51RC) Which is IC 303 and is an 93C56 chip which is a 2KBit chip (256x8) Which I have yet to read on my working UPS.
So yeah a fun project to say the least and hopefully one that will have a good outcome.
I have also ordered some 93LC66B1's and have the equipment to replace the onboard one if all else fails.
Just change the extension from "HEX" to "BIN" and you'll be fine, Forum doesn't like BIN files :)
Offline AstroAU
« Reply #16 on: April 09, 2024, 07:22:25 pm »
Well after getting a programmer and then the correct accessories to do the job at hand.
We discover that the chip (93LC66B1) holds only the serial number of the device and other configuration information.
Having acquired 10 of these devices and reprogramming said device OFF the sub board as they won't program ON board.
We powered up the UPS expecting LIFE to come back. But alas this wasn't the case.
Delving further into the main board and observing those 6 pins. We are of the assumption that they are an ISP connector for programing said device and so forth. BUT we will need to investigate this further.
Having bought an ISP programmer (Dirt cheap) we will see where this goes.
I also have some AT89C51RC chips in the post which is a micro controller with 32KB of memory on board. Yes we have the DATA sheets on these too...
This is an interesting project.
Anyone else with updates to this issue. Anyone resolved it yet ??
Also will do some more research. Gotta be information on the devices somewhere.
Offline Fish_bonz
« Reply #17 on: April 12, 2024, 01:28:24 am »
I've also recently bricked my SMT1500. It's also a 2011 model year with the same board 640-3081A_REV06 noted above.  That said, I'm following this thread carefully to see if anyone can figure out how to get this working again. I'm of little help when it comes to circuit knowledge but not afraid to get my hands dirty either.
In the interim, I had to break down and purchase another SMT1500 (2010 model) on the cheap. It's being shipped so not sure what rev board is on the 2010yr model.  Don't know if they can be swapped if they are different either.
What is disappointing is that APC should be reaching out and owning up to this bricking problem. They just shrug it off and state that you should not update or should call first. I'm obviously not the only one that has bricked the unit going from 9.04 ID18 to 15.0 ID18. They should probably pull that firmware to figure what's going on unless it's by design....I have other SMT750's that I had no issue with updating firmware. One dated from 2011 and another 2022.
Peter
Offline asis
  • Country: ru
« Reply #18 on: April 12, 2024, 12:06:54 pm »
???ҐS361030X7272  mSra-tPUS5100                  MS1T05I0            FFFFFFFFFFFFFFBR7C            FFFFFFFFFFFFFFOltteG orpu1      FFFFFFFFFFFFFFPU SuOltte s    ??         FF??ґ?FF????FF?
????????FFFFFFFFFeSvrreU SPFF
???ҐXS6301032727  Smart-UPSS1500               SMT1500I             FFFFFFFFFFFFFFRBC7           FFFFFFFFFFFFFFOutlet Group1   FFFFFFFFFFFFFFFPSU Outlet s    ??         FF??ґ?FF????FF??
????????FFFFFFFFServer UPS
IC904 93LC66 Most likely, this is a profile for the server for managing group outlets and time delays
(Outlet Group 1) via the NMC card.
Older models provide control of two groups of controlled sockets (Outlet Group 1 & Outlet Group 2).
They can be activated via the control panel or via an NMC card.
The SMT1500RMI2U is equipped with a PCB: 640-3081J-Z-001 1335BSAA15655138 and a relay RY901;(RY902), with the help of which a remote power reset is performed connected equipment.
At the beginning of the dump there is the SN/production date (S361030X7272), device type, model, battery type, outlet group number and timing parameters.
By rearranging the letters, you can match it with the S/N (XS6301032727) that you have on the UPS case.
Remote control of group sockets via LAN/Internet can be similar to the Wake On LAN protocol.
IC8 (LC93LC56) contains the UPS SN and calibration constants of the control controller IC11 (AT89C51RC).
IC303 is the reset circuit of the MC34064.
Offline AstroAU
« Reply #19 on: April 12, 2024, 03:44:00 pm »
Howdy all,
I've done what Fish_bonz has done and that is Purchase another SMT1500i UPS from Ebay from the UK, which was 95 pounds and 88 pounds shipping, add sundry items to the purchase, convert to Australian Dollars and OUCH.
Comes with NO batteries but is guaranteed working and by the looks original box too.
Looking at the serial number of the unit, it'll be an ID18 setup. SO once I have that in hand (About 3 weeks away) I'll be able to disassemble this working unit (After testing) and remove the main Micro controller off of it (AT89C51RC)
Then put a socket on the board for this device. Read the chip, program a new one. test that out in the unit. then if that repairs it then replace the chip on the other UPS and bring it back to life.
Lots of if's and but's and possibilities.
Ahh the joys of electronics, internet searching and lack of information...
Offline AstroAU
« Reply #20 on: May 05, 2024, 06:57:57 pm »
Just an update of sorts.
UPS from the UK arrived, but it wasn't in an original box but some other thing which was a thin  box, the unit had a thin layer of bubble wrap around it and the box was filled with packing peanuts UGH...
The box was not in a good shape and upon inspection the UPS had been dropped and suffered damage to the left rear of the unit.
Using my metal working skills we straightened the bend in the case.
Inserting a new set of batteries that I'd ordered while waiting for the unit to arrive, building the battery pack with connector and fuse (100A) and subsequently powering it up all looked good.
UPS firmware on the sub board was 8.8 and via USB we upgraded that to 15.0 and didn't brick this one :)
It works fine BUT the display goes blank after several days of use. Inserting network card and checking it's configuration. The display is set to permanently ON. So it does have a fault.
Going through Ebay to resolve this but that's another story.
Anyway, The sub board with it's STM32F103RCT6 ARM processor, needs the right piece of hardware to read that. I've got the software for the reader / programmer from this site...
https://stm32-st-link-utility.software.informer.com/
and subsequently ordered also a STM32 reader/programmer that only costs a small amount from Aliexpress.
the UPS IS ID18 so that's a plus. So once I've got that NEW reader on hand then we will read the contents of the sub boards ARM processor.
This sub board is for some basic interfacing to the main UPS board as when I put the working board into the dead UPS, the alarm didn't go off, the display came to life BUT it couldn't control the UPS as it didn't see it.
So once we get this sub board back to life it looks like we WILL need to pull off the AT89C51RC micro controller from the main board of working UPS. Put a socket on the board and read the data from the controller.
Drop in the other controller from the dead UPS and reprogram that and put a socket on that board too and hopefully we will get them both working again.
I do have 44 pin PLCC sockets on hand as well as 8 AT89C51RC micro controllers that came in the post.
Will update in a while when I've got the DATA from the ARM Processor and micro controller for all to use
Looked into the SMT18UPS_15-0.enc file and discovered the extension means it's encrypted and in all things it's a base 64 encryption, so good luck with that :)
So yeah we did look into that as well with no joy.
Photo's of the damage...
Offline DavidAlfa
« Reply #21 on: May 05, 2024, 07:34:00 pm »
.enc might be anything.
Offline flaotte
« Reply #22 on: May 06, 2024, 01:39:58 pm »
base64 is just way to transfer binary data over text symbols.
https://en.wikipedia.org/wiki/Base64
there is no key for encryption, you can encode/decode it with any free tool.
Offline AstroAU
« Reply #23 on: May 06, 2024, 03:20:48 pm »
Ahh ok, will look into that further. Thanks flaotte
Offline DavidAlfa
« Reply #24 on: May 06, 2024, 08:55:37 pm »
Definitely not base 64!
The tool is java-based, so much easier to reverse engineer.
You can unpack LaunchFUW.exe with 7zip.
Navigate to com\apc\microlink\fwtool.
Open each class files with  in Recaf.
There's some interesting stuff:
DESEncrypter.class
public class DESEncrypter
implements IEncrypter {
    private static final String kENCPREFIX = "SOELM";
    private static final String kENCSUFFIX = "EOELM";
    private static final String kKEY = "H25s@ase";
    public String doEncrypt(String plainText) throws InvalidKeyException, NoSuchAlgorithmException, InvalidKeySpecException, NoSuchPaddingException, IllegalBlockSizeException, BadPaddingException {
        byte[] keyBytes = kKEY.getBytes();
        DESKeySpec desKeySpec = new DESKeySpec(keyBytes);
        SecretKeyFactory secKeyFactory = SecretKeyFactory.getInstance("DES");
        SecretKey key = secKeyFactory.generateSecret(desKeySpec);
        Cipher cipher = Cipher.getInstance("DES/ECB/PKCS5Padding");
        cipher.init(1, key);
        byte[] textBytes = plainText.getBytes();
        String encryptedText = kENCPREFIX + this.byteToHexString(cipher.doFinal(textBytes)) + kENCSUFFIX;
        return encryptedText;
    private String byteToHexString(byte[] byteBlock) {
        StringBuilder hexString = new StringBuilder();
        int i = 0;
        while (i < byteBlock.length) {
            byte b = byteBlock[i];
            String str = Integer.toHexString(b);
            if (str.length() > 2) {
                str = str.substring(str.length() - 2);
            if (str.length() < 2) {
                str = "0" + str;
            hexString.append(str);
            ++i;
        return hexString.toString().toUpperCase();
FWToolConstants.class
    public static final String kHashPassword = "o9aZNAPyYcxs86ysOpGUdg==";
    public static final String kSecretKey = "apcschneider@2021";
UtilType.class
    private static int deviceID = 0;
    String originalString = "apc@123";
    private static SecretKeySpec secretKey;
    private static byte[] key;
VerifyFileCompatibility.class
Some stuff going on here, too.
VerifyFileCompatibility$FileHeader.class
Here you can see the firmware file has a 128 byte header, might include a key, keep searching in other class files and you migh find out.
Also there're some details about how to parse the file:
    public void parseData(byte[] data) {
        this.version = data[0];
        this.command = data[1];
        byte[] size = new byte[4];
        System.arraycopy(data, 6, size, 0, 4);
        this.fileSize = this.unsignedBytesToInt(size);
        byte[] id = new byte[2];
        System.arraycopy(data, 12, id, 0, 2);
        this.deviceID = this.unsignedTwoByteArrayToInt(id);
        UtilType.setDevideId((int)this.deviceID);
        FWToolApp.theLogger.debugMsg("deviceID:" + this.deviceID);
        byte[] filecheck = new byte[2];
        System.arraycopy(data, 16, filecheck, 0, 2);
        this.fileChecksum = this.unsignedTwoByteArrayToInt(filecheck);
        this.index = data[18];
        this.fwversionStringSize = data[19];
        this.fwversionString = this.setValueFromByteArray(data, this.fwversionStringSize, 20);
        FWToolApp.theLogger.debugMsg("fw version String:" + this.fwversionString);
        this.byte64 = data[64];
        byte[] check = new byte[2];
        System.arraycopy(data, 126, check, 0, 2);
        this.headerChecksum = this.unsignedTwoByteArrayToInt(check);
        byte[] xmodemstring = new byte[33];
        System.arraycopy(data, 68, xmodemstring, 0, 33);
        this.stringToWaitfor = this.setValueFromByteArray(xmodemstring, 33, 0);
        if (this.stringToWaitfor.equals(Messages.getString((String)"VerifyFileCompatibility.45"))) {
            this.stringToWaitfor = null;
Also: calculatefilechecksum, calculateheaderchecksum.
« Last Edit: May 06, 2024, 09:58:05 pm by DavidAlfa »
Offline mark1975
« Reply #25 on: May 26, 2024, 10:45:08 am »
Hey guys I have been scouring the net for some information about these shitty SMT series UPS getting bricked.
I have two SMT1000 here which i bought and put new batteries in, I also ran the ID18 version 15 "Update", one using the NMS card, then the other one using a serial cable thinking that may work. Stupid mistake.
I now have two bricked controller boards. I have removed one controller from a scrap SMT1500 and this appears to have bought one of the units back to life (although it is reporting that it is an SMT1500). It seems to work fine, and warns if the load gets close to 1000VA. Has anyone tried removing the 93LC66 and replacing it with another new programmed one? I am only guessing that this may be where the corruption is happening? I have contacted schneider, they wont sell me a spare PCB (Even though they have scrap units). I would be keen to get a copy of whatever the firmware is on this chip in an SMT1000, flash it into the 93LC66, solder it onto the pcb, and see if that works. APC should be made responsible for this failure of firmware upgrade. Judging by the tech i had on the phone, they know this is a problem.
Would anyone have a .bin file of that chip out of a 1000VA version unit? I can do some testing and get back.
Mark
Offline AstroAU
« Reply #26 on: May 26, 2024, 01:22:39 pm »
It is a very Basic EEPROM that only holds 512 bytes of data in a 16 bit format, so should be easy to look into the one I posted earlier.
As for the contents of the ARM processor on the daughter board...
WE acquired an STM8 / STM32 reader programmer from AliExpress with Dupont female to female connector cable and have read the contents of a working ARM processor.
Referring to PeeJay's post back in Feb for the pinouts of the white JST connector that I'll repost below.
6 - Reset
5 - Ground
4 - PB3 / JTDO
3 - PA14 - SWCLK
2 - PA13 - SWDIO
1 - VCC
The corresponding pins on the STM32 (ST-LINK V2) programmer are.
1. RST (Reset)
2. SWCLK
4. SWDIO
6. GND
8. 3.3V
JST connector - ST Link V2 connector
  6  -   -   -   -   -   -   1
  5  -   -   -   -   -   -   6
  4  -   -   -   -   -   -   NC
  3  -   -   -   -   -   -   2
  2  -   -   -   -   -   -   4
  1  -   -   -   -   -   -   8
The reader / programming tool needs to have it's address range changed from 1000H (HEX) to 40000H HEX or 4 kilobytes to 256 Kilobytes.
As the ARM processor STM32F103 RCT6 is a 256KB EEprom device and also has other internal memory.
I still need to REMOVE the AT89C51RC chip and read that from the good UPS. Unless I can read / program it from the technology connector (J606) that is on the main board as discussed above but were still researching that option
Now for the attachments, a couple of photo's showing the interconnect from the ST-Link V2 to the sub board of the UPS
Along with the subsequent 256KB file from the STM32F103 RCT6 ARM processor chip. NOTE: Rename the "HEX" file to "BIN" and you'll have the right extension for the programmer....
Foot note: you can obtain the STM32F103 RCT6 IC's through EBay for about $4 each (Lot of 5 for about $22 AU)
                 Likewise the AT89C51RC cost me $100 AU for 8 chips (Minimum order) from EBay as well.
My 2nd board that I was playing with has developed a short that I cannot see so that's set me back a bit (Getting tools to inspect board)
« Last Edit: May 26, 2024, 02:00:14 pm by AstroAU »
The following users thanked this post: mark1975
Offline DavidAlfa
« Reply #27 on: May 26, 2024, 02:47:22 pm »
So what's this stm32 dump for? SMT1500? In working state?
Please make this clear in your message to avoid mistakes.
Offline AstroAU
« Reply #28 on: May 26, 2024, 05:54:30 pm »
Sorry for the confusion.
Yes this is a working dump from the daughter-board's STM32F103 RCT6 which has the latest firmware version 15 contained within it.
This is from a working SMT1500i as needed.
I did say in the text of my post...
WE acquired an STM8 / STM32 reader programmer from AliExpress with Dupont female to female connector cable and have READ the contents of a WORKING ARM PROCESSOR on this board.
Offline DavidAlfa
« Reply #29 on: May 26, 2024, 07:06:59 pm »
Sorry, but I re-read your entire post several times and found no reference to 1500 or whatever, and still nowhere to be found, so that's why I asked  :)
Uploading unidentified binaries is a very bad idea, I suggest renaming that file to "APCUPSSTM32F103RC.hex_SMT1500i".
Also, instead uploading raw binaries that could get corrupted, zip or 7z is a much better option.
« Last Edit: May 26, 2024, 07:11:13 pm by DavidAlfa »
Offline AstroAU
« Reply #30 on: May 27, 2024, 04:44:11 am »
DavidAlpha writes: Sorry, but I re-read your entire post several times and found no reference to 1500 or whatever.
I wonder what the THREAD TITLE reads.... oh wait.... "Help with Bricked APC UPS SMT1500" I wonder what that's about....
But yeah the file isn't really that large only 256KB and the attachment limit of the forum is 8MB per reply by the looks of the rules seen when adding attachments.
So I just renamed the extension as the forum doesn't like BIN attachments.
I'll reattach the file with a more descriptive name for you then. But you still need to change the .HEX to .BIN though.
« Last Edit: May 27, 2024, 04:49:34 am by AstroAU »
Offline DavidAlfa
« Reply #31 on: May 27, 2024, 05:55:58 am »
But other models are mentioned in the thread too!
I'm not idiot, but "stm32.bin" is not a good idea! :-+
Offline AstroAU
« Reply #32 on: May 27, 2024, 03:12:37 pm »
Yeah good point, I was too focused on my bricked APC SMT1500i and presumed badly that others had the same issue with the same model.
 |O |O |O
Offline mark1975
« Reply #33 on: May 28, 2024, 05:58:38 am »
Thankyou AstroAU for this valuable information I will order one of these programers and have a go at getting these two failed boards going again.
A bit more of an update - I took the  93LC66 off the dead SMT1000 board and replaced the one on the SMT1500 board, whacked it back in and now the UPS is showing its correct serial number and model :)
It is quite possible the STM *MAY* have the same software on all models. I'm not sure.
« Last Edit: May 28, 2024, 09:18:43 am by mark1975 »
Offline m k
« Reply #34 on: May 28, 2024, 10:13:19 am »
Since data seems to be 16 bits and so the small memory being for RBC7, maybe that is what defines the rest.
It would also be much more practical than many complete software versions.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-YFE
