Author Topic: Help with "complementary" SCR  (Read 1593 times)
Offline vindolineTopic starter
« on: February 15, 2019, 03:33:20 am »
Help, I have a Power Designs TW6050A supply with a non-functioning over-voltage crowbar circuit. Close inspection of the board shows that CR25 let out the magic smoke a long time ago. This is an old GE part number C13F. It's an odd "complementary" SCR. The gate is on the anode side. I found a reference to it in a 1977 GE semiconductor data book.
I've had no luck finding any information about a replacement. Does anyone have any ideas?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Help with "complementary" SCR
« Reply #1 on: February 15, 2019, 07:15:08 am »
PUT.
Any should do, which is fortunate because basically only one exists anymore: 2N6027.
Seven Transistor Labs, LLC
The following users thanked this post: vindoline
« Reply #2 on: February 15, 2019, 01:30:25 pm »
Tim, Thanks so much! Of course they changed the name  :palm:
Offline JoeO
  • I admit to being deplorable
« Reply #3 on: February 15, 2019, 03:51:43 pm »
The GE Semi Data Book link in your first post has a lot of useful information.
Thanks for the link!
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
« Reply #4 on: February 15, 2019, 05:40:03 pm »
You're welcome  :)
Offline Chris56000
« Reply #5 on: February 15, 2019, 05:56:44 pm »
Hi!
There's also a Pro–Electron coded device called the BRY39 that used to be used in the field timebase oscillator stage of early s/s colour TV sets that had both an anode–gate and a cathode gate, you might be able to try this device with a 1k resistor between cathode–gate and cathode (use an ⅛W resistor) to prevent random triggering!
The BRY39 shouldn't be too hard to find as vast piles of early solid–state TV sets used it!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
« Reply #6 on: February 16, 2019, 03:01:33 am »
Chris Williams
Thanks! It's great to have several alternatives. The BRY39 looks to be rarer/more expensive than the 2N6027.  I'll give that a try first and report on its performance.
Re: Help with "complementary" SCR - FIXED!
« Reply #7 on: February 25, 2019, 08:56:05 pm »
Just to wrap this up, I got the 2N6027 and replaced the blown C13F. The over voltage crowbar is now working fine  :-+. Thanks everyone!
