Polystyrene, and always in pF, unless marked ( for really big ones) in uF. Easy to tell from the ends being conical and clear, along with the spindly leads. Note they really are heat sensitive, IR reflow will kill them, and soldering really needs either under 3 seconds per joint or a heat shunt on the leads. They melt at 70C.
