So, I have a sony tape deck, model tc-k615s.
https://elektrotanya.com/sony_tc-k615s_sm.pdf/download.htmlIts having a problem, and Im hoping someone might have 2 cents or some perspective that might help.
So before getting it I was told it was blowing fuses.
I replaced the fuses, tried to power it on, and no front display, fuses lasted through the first power attempts, but shortly after that the fuses did blow without my knowing.
Then replaced the bridge rectifier diodes. Then replaced the fuses. Also replaced a transistor that had failed.
That got the front display working, and power seemingly, but upon powering up the thing studders immediately, loses power, then comes back on again within 1 second, repeating the same sequence. I believe the reset on the CPU is behind it.
& It seems the cause is to do with the wrong voltage being sent to the capstan motor.
On IC701 I get this on voltage
pin 1 -12 (supposed to be -2.8 )
pin 2 -4
pin 3 -4 (pin 2 & 3 supposed to be 0 according to service manual)
pin 4 -18/19 (supposed to be -8.4 )
pin 5 -4 (supposed to be positive 7v)
pin 6 -4
pin 7 8.3
pin 8 8.9 (pin 7 & 8 correct)
I removed capacitors c705 c704 c702 c701, tested capacitance. checked out.
Removed q705 q704 q703, they tested good as well.
I wondered about ESR because I didnt check for that... It is about 20 years old now.
I replaced LA6500 but in futility as the problem was further up the line.
Although LA6500 was feeding negative voltage to both sides of the capstan motor it seemed.
I tried probing the board with a multimeter to find any shorted traces, but didnt find anything.
Did seem to find a cold solder joint. But freshening it up didnt cure the problem.
Ive tried to corner the culprit in every way I could think of but Im at a loss.
Also 1 annoying thing about the service manual is that it doesnt mention AC on the transformer, and I would like to test that and make sure its all right, but didnt find any reference.
Oh, another interesting thing is that.. If I unplug the capstan motor from the main board, that stuttering reset doesnt happen.
Anyway, if anybody could take a look when they have a chance and give any advice it would be greatly appreciated and mean a lot.
I have a feeling this might be an obvious problem/solution for some of the many wise members here.
Thanks in advance.
Much Love
