Hi all,
Finally got to test table again. Before testing I replaced the DC input terminal, just in case.
The problem remains, although this time I discovered something very interesting.
I connected each motor one at a time to each motor output and tested UP/DOWN movement. The only terminal that was acting suspiciously was the middle terminal. When ever a motor was connected to the middle terminal (didn't matter which motor) and I would press UP on the control unit, the motor would move UP and then for a brief second DOWN (automatically). The only terminal that did this was the middle motor terminal. I also discovered that when all three motors were connected I could move all of them DOWN, but not UP. I'm thinking downward movement requires less power.
My thinking now is that something in the middle motor terminal is causing this. The component groups for all three terminals are identical so it "should" be pretty easy to find what is wrong.
