Are you *really* sure it was the ferrite that was damaged? 60 ohms at 25MHz with a through hole part has gotta be rated for many amps, and it's literally just a wire through the center of a ferrite material.
I would suspect virtually any part around it before I suspected the ferrite, though there is some slim chance it could be the fault. I would suspect a schematic or parts not matching the implemented circuit long before I would suspect a ferrite bead exploded.
If you really, really, still think it's the ferrite, then the recommendation of "any old bead" fits well. Find something that looks close to the original part and has an impedance rated in the same ballpark. You could even buy a small ferrite ring and just put it around the leg of a transistor to similar effect. It's also true that if you omitted the part in favor of a wire jumper and it was originally at fault, the device would work. Adding it in may improve noise performance somewhat, it was there for a reason initially, but there are virtually no designs where the ferrite bead when omitted can cause a total failure.
