Hi , all
like many users here i have bought used broken fluke 87 iv , outside/ really abused condition
but after reading many posts from this forum have read out how it should to be when everything works .
This one is unfortunately got some kind of electric shock , i have checked: movs are ok , fusible was 3.3k ohms ,
have replaced with OHMITE OY102KE
it still reads wrong values
on dc 1.5 volt aa battery shows 3.23
then after replacing fusable now is 2.225
still no good ,on ohms settings shows 0L if i try to measure something it begins to measure and then stops on 0L and not responding anymore
have noticed one missing blown smd resistor on pcb i need help from someone who has 87iv or 187 and can measure-check component to indetify what i need to buy to replace on mine
Sadly previous owner removed fuses together with carrier
Here are few pics from device and pcb
Cheers
