Yes, it's connected to transformer pin 10, through a diode.It doesn't seems to be open (I measure about 1.2 ohms through the inductor) but it's not working (it's burnt and with a magnify lens I can see a crack in the middle of the component).
The resistance is the same as the other inductor. The diode is ok and the cap isn't shorted. But when I've turned on, smoke coming from the inductor and voltage rails all messed up: +80V rail is now 24 V and +15 V is now 2 V.
