Author Topic: help with HP 41800 probe  (Read 207 times)
Offline WB8PFZ
« on: March 28, 2020, 03:23:16 pm »
I received my Ebay probe yesterday. It works and is in nice condition except for the tip. By my measurements it is 1/8 inch short of making contact with the adapters. There was a small piece of broken plastic on the front tip that I removed. Can someone explain what I am missing? If I take the plastic sleeves off the adapters it will make contact. Chances are HP no longer has parts for these? Thanks Mike
Offline JKKDev
  • Country: si
Re: help with HP 41800 probe
« Reply #1 on: March 29, 2020, 08:56:45 am »
Check page 6-2 of this document.
Offline WB8PFZ
« Reply #2 on: March 29, 2020, 02:27:06 pm »
I still can't see what is going on. I do not want to destroy this trying to get it apart. I am not sure if HP has parts to fix it or not. I would like to see one, touch one to see what is missing. Thanks Mike
Offline tggzzz
« Reply #3 on: March 29, 2020, 02:38:40 pm »
Do you have parts 8 and 9 in that diagram? If not then you will probably have to fabricate something.
I've successfully 3D printed things like part 8 in SLA before; they are very cheap from DirtyPCBs, but can be slow in arriving. An altenative material is Shapeways sintered nylon (whatever they call it this month). It may be necessary to be careful that a homebrew sleeve doesn't increase the tip capacitcance.
As for the parts 9, you may have to turn those yourself, or perhaps a piece of piano wire could be coopted. Don't attempt to cut piano wire with ordinary diagonal cutters.
Offline WB8PFZ
« Reply #4 on: March 29, 2020, 04:57:40 pm »
I think 8 is broke and I do not have 9. It looks like 8 screws onto 7? Would that be correct? Mike
Offline tggzzz
« Reply #5 on: March 29, 2020, 06:17:19 pm »
No idea. You have one to look at, I don't.
Offline WB8PFZ
« Reply #6 on: March 29, 2020, 06:27:25 pm »
Well since mine is broke it is hard to tell how things screw together.  :-//
