Author Topic: Help with HVAC/Refrigeration symbology  (Read 3011 times)
Offline stazeTopic starter
  • I _might_ have a problem...
    • Everybody Staze...
« on: June 28, 2017, 02:41:43 am »
Hi All,
I'm trying to repair a wine fridge, and I'm not positive about the symbology on these two mechanical thermostats. Attached are images.
I think I figured out that the triangle in the circle is the compressor, and the thing in parallel with it (connected to pin 3 on both) is a blower (this unit doesn't have one), but what is the circle with the X in it? The main difference between the two appears to just be a circle with an X through it between Line and pin 4 on the 53007.
Also, the "switch" piece, should it connect to pin 3 or pin 2 when the thermostat is on (temperature has not been reached) or off (basically, is that NC or NO)?
Thank you!
“Give a man an answer, he’ll keep his job for a day. Teach a man to Google, and he’ll be employed for a lifetime”
Offline Armadillo
Re: Help with HVAC/Refrigeration symbology
« Reply #1 on: June 28, 2017, 04:12:26 am »
Apparently the symbol does not conform to international standard like IEC, BS. I think its a mix between the company own HVAC and Electrical symbols. I suppose the X is a light indicator.
Offline IanB
« Reply #2 on: June 28, 2017, 04:23:22 am »
The circle with an X through it is a lamp. For instance, see here: http://www.electronic-symbols.com/electric-electronic-symbols/electric-lighting-symbols.htm
The switch operates according to the picture next to it: when the temperature goes down enough it moves from pin 3 to pin 2, stopping the compressor.
Offline orion242
« Reply #3 on: June 28, 2017, 09:50:54 am »
Circle with triangle is typically a pump, symbol below that is a fan.
