Hi there all. I'm a complete novice to electronics (although I am slowly learning basics) and I need some help with identifying these diodes.
The first image is a hard drive PCB. The purple diode has: QA RA13 code and is approx 4mmx2mm. The red diode has: 12T 09 code and is approx 4mmx2mm.
The second image is a mini PC. The orange diode has: J1 2 (2 is written sideways) and is approx 2.5mmx1mm.
My own research tells me that the hard drive diodes are tvs diodes therefore, I presume that the 12T would stand for 12v tvs? and I read that the QA on the second diode normally means 5v?.
As for the mini PC, I have no idea.
Can anyone help me identify these diodes so I can purchase replacements?
Thank you
(Images are in attachments)
