Author Topic: Help with identifying components!!!  (Read 425 times)
Offline rfenggTopic starter
« on: April 13, 2024, 12:21:47 pm »
Need your help with identifying 3 components from an audio amplifier.
Pic 1) Q4 which is marked as DG S19. A similar part on the same board  measures as a PNP BJT but Q4 has a short on it.
Pic 2) D5 which is marked as N2 Y5. I cannot seem to turn on any diode junction with a multimeter diode check.
Pic 3) Fuses F1 and F2: I think these are 5A slow blow fuses from Littelfuse but I am not sure which series they are from. Littelfuse usually marks the series number on the fuse body, but there is none here.
« Last Edit: April 13, 2024, 12:32:24 pm by rfengg »
Offline fzabkar
« Last Edit: April 13, 2024, 05:11:51 pm by fzabkar »
The following users thanked this post: rfengg
Re: Help with identifying components!!!
« Reply #2 on: April 13, 2024, 05:54:23 pm »
@fzabkar You are a lifesaver  :-+
