I've rebuilt the rectifier with new diodes, and soldered new traces to the little caps under the diodes that seemed suspect.
I get continuity everywhere, a capacitor that charges, but only partial voltage (about -17) on one side of the aisle, and 50+ volts on the other.
At this point, I am wondering if I should rebuild the rectifier off circuit and patch it in, or perhaps introduce a single component rectifier that would do what I need here instead?
The more I mess with the board, the more it deteriorates, so its a risk to try and patch this rectifier again unless there is a component we have not discussed that could be influencing the voltage difference?
I guess it gets interesting?
is not the emo I had hoped for
