Author Topic: I can’t find where to solder a component...  (Read 1026 times)
Offline Andrewlee1739Topic starter
« on: March 07, 2021, 09:38:53 am »
I own an Origin EVO 17-s and a 100uf 25v capacitor fell out and I can’t find where it should go. How should I go about finding it’s home? I’ve looked all over for a diagram but I’m unsuccessful. Below are some pictures of the component and the computer it came from. The capacitor says ED(M)105°C (C)18071638 on the other side.
Re: I can’t find where to solder a component...
« Reply #1 on: March 07, 2021, 09:41:11 am »
I didn’t realize how small the pictures were. Here they are clearer.
« Reply #2 on: March 07, 2021, 09:44:17 am »
Pic 2
« Reply #3 on: March 07, 2021, 09:44:53 am »
Pic 3
Offline The Soulman
  • The sky is the limit!
« Reply #4 on: March 07, 2021, 09:58:40 am »
If anywhere, I'd suspect near the charger input.
Good luck.  :-+
Offline ogden
  • Country: lv
« Reply #5 on: March 07, 2021, 09:59:07 am »
You search for review/teardown of your device or similar. Often there's pics of boards.
https://www.ign.com/articles/2019/07/22/origin-evo16-s-gaming-laptop-review
Comparing two you can find differences.
[edit] So expensive laptop and capacitors that are not properly glued. Shame. :palm:
« Last Edit: March 07, 2021, 10:04:15 am by ogden »
Offline jpanhalt
« Reply #6 on: March 07, 2021, 11:04:29 am »
Does it still work?  If so, are you sure it was ever intended to be attached?  How long had you owned the laptop before it fell out?
Offline Haenk
« Reply #7 on: March 07, 2021, 07:00:37 pm »
I find the legs surprisingly long, it almost looks like this has not been soldered in (and have its legs cut) at all.
Offline ogden
  • Country: lv
« Reply #8 on: March 07, 2021, 07:05:42 pm »
Look how it's legs are bent. Also look at picture in URL I posted - it lies flat on the PCB. OP's cap was not glued - that's why it fell off.
