in same year this forum helps me to repair some of defect devices and in the next i will write about some finish repair projects.
But now i need help by an 2400.
all devices are calibrated annually and any time some are goes wrong. calibrated with selfbuild tool.
its devices bevor year 1999, also more than 20years running.
first i changed the caps (würth) and the fan (1570-1064-ND digikey).
the problem is -> Calibration by selfmade box testet with load. with load condition everytime the current end so near -37mA in negative voltage quadrant. positiv quadrant is good.
i solder same of the mosfets and transistor and caps with oxidized solderpoint. test voltage ,see in block picture.
calibration protocol attached
protocoll.pdf (251.18 kB - downloaded 237 times.)
but next??? what controls the current?? defect mosfet? im not sure what i can do in this error.
device off -> power on, measure an F-middlepoint is -165v to finish the boot, after that 0v.
Thanks,
