My previous posts have not been showing up. I will try again.
I'm having trouble with the connecting plugs on the pc boards. The wires are connected to the plugs by pushing the wires down between a "v" shaped pin on the plug. This is supposed to "bite" into the wire making contact. This is similar to telephone wire connectors. However once the wires come off, it's nearly impossible to re-attach the wire(s) to the plugs. I have attached some photos as an illustration. Has anyone solved this problem? Are there any replacements that use solder connections to the plugs that will fit the headers on the boards?
Any help will be greatly appreciated.
Thank you.
