Author Topic: Help with Vintage Teac V-35 tape deck  (Read 1936 times)
Offline gooseEL34Topic starter
« on: March 06, 2016, 07:06:30 pm »
Hey guys-
I was wondering if someone could offer a suggestion.  I grabbed a goodwill cassette deck (Teac V-35).  When I plug it in, the motor continuously runs.  None of the buttons will stop it (Stop, Pause, FF, Rewind, etc).
Here is a pic of the motor in question
https://www.flickr.com/photos/140022773@N08/shares/05gx70
The drive belt has long turned to goo.   No obvious burned components on the PCB nor any electrolyitics that are spewing their guts.
Thanks for any tips...
Offline karoru
Re: Help with Vintage Teac V-35 tape deck
« Reply #1 on: March 06, 2016, 10:14:48 pm »
Are you sure that motor even has the "stop" circuitry? I've seen many vintage tape decks that had motor just wired straight to power supply (or via some motor controller chip, often on separate PCB), without any ability to disconnect it while unit is on. I don't see V-35 manual available online, but on elektrotanya there's V-9000 from similar era and there the motor is just connected straight to 10V rail.
Offline RobertGogol
    • my adventure with Electronics and Music
« Reply #2 on: March 06, 2016, 10:27:23 pm »
every deck in my life has continuously running motor connected with capstan by drive belt.
I think this is ok.
« Reply #3 on: March 07, 2016, 04:42:20 pm »
Thanks guys!!!
