The DSP is held in RESET by ST PI12.
When I bypassed the RESET so I would not go LOW the DSP booted up and there was activity on the memory busses and on the op amps.
The ST PI12 seems dead. The only activity I get out of it is it's oscillator running the crystal at 8MHZ.
But that is all. Did a bit of research on ST micro-controllers but could not find anything that could match what would supposedly be the VCC & VSS.
