Electronics => Repair => Topic started by: MaxFrister on July 22, 2018, 05:41:14 pm
I recently acquired an HP 122AR oscilloscope for $11.56 USD.
(https://www.eevblog.com/forum/repair/hewlett-packard-122ar-restoration/?action=dlattach;attach=481583;image)
This is an interesting machine. It was introduced in 1958 and produced, I believe until the early 1970’s We don’t see many contemporary tech products made for a decade or more…
This was an early scope for Hewlett Packard but already has many of the features we expect on a “modern” analog scope: dual calibrated display, chop and alt, auto-trigger, B-A display, XY display, etc. It has at least one feature that surprised me: balanced (isolated ground) inputs.
It has an amazing 200Khz of bandwidth and was sold as an economical scope, costing about $625 in 1959. It was intended for low-frequency applications including audio; HP made a higher-bandwidth scope and soon introduced another.
This particular machine is painted a non-standard color and badged as “Ling electronics”. Ling made (makes?) vibration analysis systems.
The 122AR has 25 vacuum tubes, numerous neon bulbs (used as voltage references) and 2 transistors! Those lonely transistors serve an interesting purpose: they are the pass transistors for the 24V rail used for the filaments of the vertical amplifier tubes.
The 2 transistors provide a nice symmetry to my circa 1966 Tektronix 453 — it has many transistors and just 2 vacuum tubes (also in the power supply).
This machine arrived filthy inside and out. I disassembled it and cleaned it by hand. I know that people hose these machines out, but I was not that brave. A quick spot check showed that electrolytics were gone. The machine showed signs of a long, useful life: pencil marks from previous technicians and a variety of tube brands. The last calibration sticker was 1986.
Despite its huge size (and weight), this was a difficult machine to work on. Many components are packed around the selector switches or jammed in small areas:
(https://www.eevblog.com/forum/repair/hewlett-packard-122ar-restoration/?action=dlattach;attach=481589;image)
(https://www.eevblog.com/forum/repair/hewlett-packard-122ar-restoration/?action=dlattach;attach=481595;image)
Because there was no place to fit new standoffs I ended up “restuffing” the old electrolyic cans. Fortunately most of the tubes were okay:
(https://www.eevblog.com/forum/repair/hewlett-packard-122ar-restoration/?action=dlattach;attach=481601;image)
Last night, after many many hours of work, I was finally able to power on the machine:
(https://www.eevblog.com/forum/repair/hewlett-packard-122ar-restoration/?action=dlattach;attach=481607;image)
It still needs some testing and a thorough calibration but I was relieved to see it power-up without smoke. I’ll also need to make space in the rack.
That looks really good. I'm glad someone is out there rescuing this old stuff.
Apparently I’m not done with this quite yet. This machine was last calibrated in 1986 and contains 1 tube with a 1985 date code (the earliest is a 1942 tube).
In working through the calibration procedure, I found 2 problems:
The B channel amplitude changes 6.3% with 127V AC (limit is 3%). The A channel is stable, so this is probably a tube in the B vertical amplifier.
I am unable to compensate the B channel in the 10V range. I’m guessing this is unrelated to #1 and is some component in the B attenuator.
Next I’ll try swapping tubes between A and B and to look closely at the attenuators.
