Author Topic: Fluke 189 problems  (Read 655 times)
Offline rivestTopic starter
Fluke 189 problems
« on: November 15, 2022, 07:38:02 pm »
There are 2 major problems I'm having with my Fluke 189:
1. The mode selector switch is off by one. ie the 1st stop is VAC but goes to mVAC, 2nd stop is mVAC but goes to VDC, and so on. The sequence becomes ok after Temp. (the current and logging stuff)
I've tried opening and cleaning the contacts with alcohol but it didn't help.
2. The readings are all messed in all modes.
Is there something I check or do real quick before I send it off to a repair store?
Online coromonadalix
Re: Fluke 189 problems
« Reply #1 on: November 17, 2022, 05:43:15 pm »
Has it been zapped by an high voltage spike ?
Have you physically checked the dial contacts   you have 4 of them if i recall
And you have to sync the dial hexagonal hole with the function ??
