Some devices just shine with extreme quality once you take them in your hand. For example, take this battery case from small battery operated industrial instrument (~1988-1990 vintage).
It has very sturdy plastic case (no give or rattle). Battery attaches to main unit via massive brass (?) contacts and have locking mechanism. Once connected, it is rock solid. Two side contacts are for charging internal batteries.
Case is made from two plastic pieces, connected with two long screws. Screws have metal (!) (again, it seems like brass) caps to cover them from regular user - it is not supposed to come apart. Screws also have double grommets/soft washers to seal the unit. There is rubber seal around the main plastic lip.
Inside there is simple charging circuit, 2 AA sized batteries, paper for isolation and flex circuit for connections. All external connections are riveted (!) to flex circuit. Batteries have leaked slightly, but it would take much more to take out such sturdy construction.
As you can see, batteries are completely dead, but all is easily repairable. Can anyone give a hint what type of batteries are in that case? It looks like NiMh or NiCd cells, but I cannot discern. Any hints?
