I'm trying to repair a Hitachi LCD television. It's an ultravision, model number L42S504. I followed the troubleshooting procedure in the service manual, and it says to replace the mainboard. I made some attempts to repair the mainboard, but was unsuccessful.
The power supply board seems to work fine, and if I use a jumper to put 5v to the PS_ON pin, the backlight turns on and I can get 12v and 24v from the power supply.
So I decide to replace the mainboard, which has model number 715G3269-M01-003-005K. Here are two pics of the dead board in my TV.
When I look up this number on ebay, I no matches. However, if I just search for 715G3269, I get several matches like that look like the right board, but the number on them is 715G3269-1. For example,
http://www.ebay.com/itm/INSIGNIA-or-HITACHI-MAIN-BOARD-715G3269-1-/301275415503?pt=US_TV_Boards_Parts_Components&hash=item46256a03cfI don't know much about board naming conventions--I don't know if this board on ebay, the 715G3269-1, is a new revision that will work fine or if it won't work. Do you guys have any advice?
Thanks.
M.S.
