Author Topic: Help for identifying 5.08mm connector  (Read 1413 times)
Offline manuTopic starter
« on: October 26, 2015, 10:31:21 am »
Hello,
I cannot find a reference for a 2-pin 5.08mm pitch plug with a cross style section (please see attachments).
This connector is a part of a swing-gate opener and supplies 24Vdc.
If you know where to find it and it pcb corresponding header, please let me know.
Thanks,
« Last Edit: October 26, 2015, 10:54:42 am by manu »
Offline SL4P
  • There's more value if you figure it out yourself!
Don't ask a question if you aren't willing to listen to the answer.
Re: Help for identifying 5.08mm connector
« Reply #2 on: October 26, 2015, 02:11:29 pm »
Thank you !
You are probably right, it might be a 5mm pitch as I don't find any 5.08mm header with this footprint.
