:-+PROBLEM SOLVED, Sucess for the Hitachi V-352, Trace is back Bright and Beautiful and the intensity control working again.
but first I Want to thank GEORGE E For guiding me in the right direction, both his knowledge and skills of scopes and kindness
and patience taught me a lot, saving me a lot of time changing of parts and money Much Appreciated. Secondly i did want to mention.
I did Replace about 5 caps that were open such as C1101 C1103 C907, C908 and C912 IN the low voltage rail and Z Amp
George E I did check the resistor you mentioned R 1024 22 MEG and it checked GOOD Along with the others R906 R907 R904
R 908 all were ok. finding nothing wrong at this point i got to thinking if a Pulse comes from the Z amp why not check the resistors.
in that circuit. just for curiosity well guess what the culprit was R912 Resistor a 100-ohm 1/4 watt it was toast. causing no voltage to collector
of transistor TR904 there by cutting off a pulse signal. I WOULD have found this problem a lot sooner if the schematic showed voltages. On all the transistors but they don't. incidentally there are some discrepancies in the schematic which make it harder to troubleshoot. be aware of this. R910 ON Schematic says 22K IT'S REALLY a 10k and C 912 ON SCHEMATIC SAYS 47 MF it really is
4.7 mf
any way to continue I DID PULL THE TR904 Z amp out of the circuit just to check if it was open or shorted with my Heathkit IT-18
Transistor checker it checked OK. Next, I just tacked the new resistor a 100-ohm 1/2 watt on the soldered side of the board as a
temporary hold and turned the scope on and a bright trace appeared. And the intensity control was working again. It was so bright.
I had to turn the crt bias down boy did that give joy and happiness. I Ran the scope for about 1/2 hour and pulling the plug of course.
the tacked in resistor was just barly warm to the touch. To complete the job i had to use tweezers on opposite side to install that resistor permanently. no room for hands in there. The crt breeds life once again. Hope this thread helps anyone with a Hitachi V-352
OR V202 MODEL or possibly other V MODELS . TOM V
